Тема: Сингл-спид от Rammstein
https://www.youtube.com/watch?v=WnCYav7r4Ik
Reise, Reise - with the new single-speed "Bike Rammstein".
Limited to only 100 bikes, now exclusively available on the RammsteinShop.
https://shop.rammstein.de/en/catalog/pr … ts_id=1391
A high-quality, exclusive single speed bike in a limited edition of 100 – designed and built in collaboration with Schindelhauerbikes in Berlin. Specially designed frame geometry and innovative technology fuse with purist Rammstein design.
Frame: aluminium (AL6061-T6), triple butted aero tubing, horizontal drop outs with crocodile belt tensioning system and belt port, integrated seat post clamp, smooth welded, forged dropouts for a clean transition without an apparent weld seam, head tube milled with Rammstein-Logo, down tube with black reflective Rammstein-Logos
Fork: straight aluminium fork
Headset: Tange Seiki full integrated
Power: Gates Carbon DriveTM CDX CenterTrack - 118T, Transmission with sprocket front 60 and rear 22 teeth
Crank Set: high-qulity aluminium crank with hollow axle, black anodized
Bottom Bracket: BSA external bearing shells for hollow axle
Pedals: Urban Pedal, aluminium, CNC machined, black anodized
Stem: integrated handle bar stem combination
Handlebar: integrated handle bar stem combination
Saddle: black leather saddle with Rammstein metal plate
Seatpost: Kalloy LCS patent, two bolt system for a precise adjustment
Grips: black hand-sewn leather grips
Wheels: high-quality industrial bearing high flange FW hub, high-quality industrial bearing Flip-Flop RW hub black, Alexrims CX30 silver brushed and anodized, DB spokes black, FW radial - RW 3-cross
Brakes: Tektro R317, Tektro FL750
Tires: Conti Sport Contact 28-622
Weight: 8,6 kg
Mudguards: mudguard mounting possible
Carrier: front pannier rack mounting possible
